4 weeks by cncdivi
During the festive Holiday Season, we all tend to take a pause from our usual work routine, reserving most of the time for family interactions. However, if we’re lucky enough, slipping away to our workshops for a few hours here and there becomes possible. I perceive the Holiday Season as the perfect opportunity to embark on a project that enhances productivity in your Home Shop. Hence, here are 8 small-scale projects that you can tackle during this period, each promising to significantly boost your shop’s efficiency.
1.  Upgrade your Shop Vac with a Cyclone Dust Separator
I’ve got a medium-sized Shop Vac that I use a lot.  Shop Vacs are essential to keeping your shop tolerably clean, but like any other tool in the shop, they can be hot rodded to make them better.  You could get a bigger Shop Vac, of course, and I will probably do so when this one wears out.  You could make a cart for your Shop Vac that carries all of its accessories and makes it easy to coil up the hose so the whole thing is compact and easy to store out of the way.  That’s another thing I should do.  While I’m at it, I will likely turn that rack into a general purpose shop cleaning supplies cart, seems like the thing to do.
But probably the biggest upgrade I’d like to make to it is to add a Cyclone Dust Collector.  These handy gadgets use centrifugal force to pull most of the dust out of the incoming stream.  They really save on your Shop Vac’s filter.  Mine needs replacing as I write this, and the oils common in machine shop refuse seem to be particularly hard on it.  The very fine dust common in woodworking also clog your filters fast, particularly if you want to run the Shop Vac not just for after the job cleanup, but on an active machine for dust collection.  A Cyclone Dust Separator can really help with this.  They can also increase the capacity of your Shop Vac before you need to empty it.
There are quite a few aftermarket add-on Cyclone Collectors available that you can use in conjunction with a 5-gallon bucket or even a full-sized trash can plus your Shop Vac.  Here’s a simple Cyclone from Instructables made from a bucket and PVC pipe fittings:
Cyclone
Simple Cyclone Collector made of PVC Fittings and Trash Cans…
Cyclone2
Aftermarket Cyclone on a custom stand with ShopVac…
While the pipe fitting and bucket collectors work reasonably well, Cyclone Collectors made with the conical shape will produce better results as they’re much more efficient.  Have you got a 3D printer yet?  Printing a Cyclone Collector seems like an ideal project if your 3D Printer has a big enough work envelope.
2.  Build a Welding Cart
We just introduced our Welding Cart Idea Page, so I won’t spend too much time here other than to say I have sure gotten a lot of use out of my simple one that I threw together in an afternoon!
 BigRedTable
3.  Put in a Shop Air System
I love my Shop Air system.  Air Tools can be a touch noisy, but they’re so much nicer to work with than heavier electrical tools because they’re so lightweight.  A nice Shop Air system consists of:
–  A Good Compressor.  A had one of the big Sears portables for many years and it was mediocre at best compared to a good compressor because it was too loud and had to run too much to satisfy my shop’s air needs.  I bought an Eaton fixed industrial compressor and it was heaven.  Not only is it much quieter and runs less often, but I stuck it in another room so I can hardly hear it.
–  Plumbing.  Do it right.  Avoid PVC (it turns into shrapnel in the end), make provision to trap water, and so on.  Here’s my page on plumbing your Shop Air System.
–  Air Tools:  The sky is the limit and you can get all sorts of neat air tools.  You’ll want the  basics to start–spray guns, impact wrenches, socket wrenches, grinders, and air drills (really handy for tight spots).  After that, get into whatever fits your fancy.  Additional air tools make great gifts for the Holidays too.
Do you already have a decent Shop Air system?  Excellent, how about some upgrades:
OLYMPUS DIGITAL CAMERA
Hose on a reel, air tool rack, and blast cabinet.  That’s the old Sears compressor I started with.  The air tool rack is an easy project and organizes your air tools. I keep the oil on a little shelf above them and squirt a bit into each tool before I hook it up to the air hose to keep them lubricated…
compressor aftercooler
How about an aftercooler to cut down on the moisture in the air lines?  This is another easy project.  While you’re at it, add the automatic tank drains that let the water out of the tanks every time they depressurize, also quick and easy to install and saves you fooling with it.
4.  Build a 3D Printer
I can’t imagine a more fun Holiday Gift than a 3D Printer kit.  We had fun building our Rostock Max here at CNCCookbook, and it would require just about the right amount of time for a Holiday project.
Don’t have a 3D Printer yet?  Build one–it’s a great Holiday project…
5.  Build a Belt Grinder, Disc Sander, or Die Filer
The tools are so handy for so many different purposes: deburring, decorative rounding, and a wide variety of other tasks.  They’re not very hard to build either.  One of my best early machining projects many years ago was my disc sander which I still use constantly:
I made this disc sander years ago and still use it constantly…
 Belt Sanders can be even more useful:
Shopmade Belt Grinder uses a U-Joint as the arm pivot…
We’ve got a big page of Belt Grinder/Knife Grinder ideas for you to check out when designer your own grinder project.
Have you got both a belt and a disc grinder?  Well how about a die filer?  These are really neat little machines that reciprocate a file up and down:
die filer
This is Neil Butterfield’s slick little die filer made from an MLA Kit
As mentioned, Neil Butterfield’s Die Filer is from an MLA kit, which is available quite reasonably and only requires a 9″ lathe and drill press to complete.  These little machines are considered obsolete, but they sure are handy.  You can either find an antique, try the MLA Kit, or build one from scratch.  The reciprocating assembly wouldn’t be that hard to craft.
6.  French Fit Your Tool Storage
There’s nothing like increasing your organization to increase  your productivity, and French Fitting (also called “Tool Shadowing”) is one of my favorites ways to improve organization.  It basically means going into your tool drawers and providing them with custom fitted pockets in the shape of the tools that will be housed in the drawer.  Every tool has its place and it’s very easy to see which tools are out roaming around somewhere in the shop and still need to be put away.
Here are some typical examples of French Fit Tool Storage:
Micrometer door with pockets for each mic and accessories…
There are a number of ways to create French Fit trays for your tools.  First thing is to choose a material.  I’m quite partial to using two layers of foam, one matching the tool chest’s color (red in my case) and one black, with the black on top.  This is just what’s been done in the photo above.  You can join the layers with some 3M spray on adhesive.  French Fitted pockets can also be made in wood, and there are many who feel that the natural oils in the wood help protect tools from moisture.  I’ve even seem them done very nicely in poly board and other plastics.
Creating the pockets may be done via either CNC with a router for any material or a laser cutter for foam.  There are pros and cons to each approach and in the end it’ll likely boil down to what you have access to.
Here are a couple of good article links with more on French Fitting:
–  Laser Cut Foam Inserts for Tool Boxes
–  Tool Foam Source and Directions to Cut With Routers
7.  Organize Your Small Parts Storage
Small parts are a constant requirement if you do many projects.  Left to their own devices, they quickly clutter a shop and you find you can never find the small part you need, whether for lack of organization or because it really isn’t there.  So you head out to the hardware store or place an order with McMaster Carr and the vicious cycle continues.
Adding some organization for small parts and keeping some inventory on hand for commonly used parts can really crank up your productivity in the home shop.  I built this organizer for my shop:
Small Parts Storage
Each plastic box holds a particular hardware size.  I built this years ago and it’s become overrun.  I need to start work on Parts Organizer 2.0!
I built it years ago and while it helped tremendously, it’s become overrun.  I need to start work on Parts Organizer 2.0!  But just to give an idea, when I go to the hardware store for let’s say fasteners, I never just buy what I need.  I attempt to buy a full box, and if not, I’ll get 10 or 20.  I’ll purchase multiple lengths and get matching washers and nuts.  All of it goes into a compartmentalized plastic box with a clear label on the outside of what sized hardware we’re talking about.  My family thought I was nuts one year when I asked them to give me these boxes already filled with hardware for Christmas, but they sure do make it easy to get on with projects.  I even stick the correct taps and dies into the box with the fasteners so the whole kit is there when needed.
Here are some other ideas for parts organization:
GrabKits
Grab Kits are much like what I’ve done already…
CardCabinets
Old office cabinets from Craigslist and other sources can be real finds…
ElecBenchParts
These little drawer boxes are more commonly seen for electronic parts but they’ll work for anything that fits.  This guy has achieved a lot of density here!
Lockers hide the clutter of it all very nicely…
PartSorter
Love this little parts sorter!
I love the little parts sorter–it’s a perfect project for a CNC Router.  We all have those “Every Unknown Part” bins full of odd sizes of hardware.  Use a sorter like this to at least break it down into hardware type.  With a little ingenuity you might get some size sorting too.
8.  Customize a Machine Station So Everything is At Hand
The Welding Carts described above bring together everything you need to weld, but this can be done with virtually any machine.  Gather up all the goodies that machine needs to have to be used so you don’t have to run around the shop looking for them every time.  Here are some ideas:
SandingMaterials
How about a sanding station?  Organize your belt sander, disc sander, hand power sanders, sanding blocks, and all the media into a station that has a a cabinet like this.  Put the finer grits at the top of the cabinet so that as loose grit tumbles down, it will be less likely to contaminate the fine grits…
DrillPressStation
Drill Press Station.  Give it a complete set of twist drills, the wrenches and keys in sizes it needs, lighting, and whatever else you may want to have to soup up your drill press
Measuring, Layout, and Metrology Area.  Get your surface plate, height gauge, micrometers, and all the myriad other measuring tools all together in one clean place where it’s easy to work with them…
UltimateSharpening
The Ultimate Sharpening Station has everything you need to keep tools sharp.  A Grinder station in general would be nice.
There are a lot of other ideas you could run with in terms of creating dedicated small functional areas in your shop that have everything you need for a particular task.  I like having a cart that carries all my mill tooling right by the mill.  It’s got collets, toolholders, wrenches, vises, clamping kits, angle blocks, and all the rest that I’ve accumulated.  Same thing for the lathe, where I use a pegboard racking arrangement behind the lathe to organize all the lathe tooling.  If you have room and special interests, you might want dedicated small work areas for electronics, gunsmithing, jewelry making, engraving, or whatever else you like to do that requires a specialized workspace.
Click here for even more Workshop Organization Articles.
5/5 - (1 vote)
