2 hours by cncdivi
CNC Manufacturing Techniques
Are you interested in gaining more knowledge about how to turn your CNC Manufacturing and Job Shop operations into an efficient one? You’re at the right source of information. This site is a collection of all our resources to compile a Cookbook dedicated to CNC Manufacturing and Machining Techniques.
Whether you’re at the very beginning of your journey to manufacture your own product, starting a new machine shop, or running an established operation and looking for ideas on how to improve productivity, this is where you’ll find that sort of information on CNCCookbook.
Here are the articles available for maximizing your CNC Manufacturing.
Basic Concepts Every CNC Machinist Should Know
CNC Manufacturing Workflow: Optimize each part of the cycle to improve productivity.
Where to Start Saving: Cycle Time or Setup Time?
What Do Top Shops Do Differently? Learn about Best Practices the Top Shops have that others don’t yet.
10 Strategies for Managing the Feast or Famine Job Shop
Lean Manufacturing Principles: Try our multi-part mini-course to get you up to speed on Lean Manufacturing fast.
Articles By Manufacturing Workflow Stage
Order & Design | Take the Order, design the Part, and prepare the g-code and any other machine inputs |
Design Discussion & Specification Cost Estimation & Quotation
Order Committed CAD CAM
Post | CNC Design for Manufacturing (DFM) Cost Estimating for Machining and Manufacturing CNC Machine Hourly Rate Calculator
3 Step Process for Choosing CAD Software 2014 CNCCookbook CAM Software Survey
Rough Stock & Consumables | Obtain rough stock and consumables and cut to size for loading in machines |
Rough Stock – Order – Inventory – Cut to Size Consumables | Bandsaw, Waterjet, Laser or Plasma Cut Rough Stock? Nesting Software from Sigma Tek to MyNesting.com: Maximize Rough Stock Utilization |
Setup | Prepare machine so it is ready for operator to produce multiple parts |
Tooling
Workholding and Fixturing
Load Program | Total Guide to CNC Jigs, Fixtures, and Workholding Solutions for Mills |
Machining | Actual CNC machining work |
Load Stock Run
Problems
Inspection Forward Part to Finishing | (More than 10 articles) |
Finishing | Final preparation of the part before delivery |
Finish Prep
Finish (Anodize, Powder Coat, etc.) Inspection/Quality Control Inventory | .
Overhead | Routine activities not directly associated with the manufacture of a particular part |
Cleanup Routine Maintenance Training | CNC Chuck Maintenance: A Kitigawa Guest Post Michigan Training Program Turns Out New Machinists in 6 Weeks
Intermediate Techniques
4th Axis Basics: Multi-part article series on what a 4th axis can do, how they work, workholding, etc.
C-Axis Turning and Live Tooling: What if your lathe was also a mill?
5-Axis CNC Benefits: What are they doing that you can’t?
RAMTIC: Super Fast Precision Manufacturing on Cheap Machines (aka What you can do with probing)
Horizontal vs Vertical Milling Machines
– Two and a Half Men: Manufacturing at Straightline Components
High Speed Machining
Lights Out Machining
– Definitive Guide to Lights Out Manufacturing
– Why Shops Run More than One Shift
Job Cost Estimation
Lean Manufacturing
Resources for Starting CNC Businesses
Machine Shop Business Plan: How to go about putting one together with samples
Turning Pro and the Lunch Pail Manifesto
Try the Free Trial Version of G-Wizard G-Code Editor…
Recently updated on April 17th, 2024 at 02:40 pm
